Last three days have been match drilling of aft window into the roll bar with #40. Then I clecoed and riveted the right side. The turtledeck skin holds did not line up well and a lot of time was used opening the hole with a scribe, and if necessary with a #30 drill bit. It has been in the 100's of degrees in Paso Robles, and this limited garage time for an old man.
